TwinTurbo.NET: Nissan 300ZX forum - Usually a bad fan clutch can be tested by trying to
jzack
on May 20, 2012 at 8:42 AM
Not in a year. The fact that it stops immediately when
posted by not4resaleZ
on May 19, 2012 at 11:34 PM
spin the blade by hand. If blades just go a bit and then meet with resistance - often means the clutch is OK. Also others have reported when the blades are spinning - a bad clutch has a howling type sound...
Really loud squeal when starting cold for about 20
not4resaleZ
15:57:01 05/19/12
Often it's the alternator belt that needs a bit of
jzack
18:22:14 05/19/12
not4resaleZ
23:34:28 05/19/12
Usually a bad fan clutch can be tested by trying to -
jzack
08:42:27 05/20/12
Spinning it by hand seems right. Some resistance. (n/m)
not4resaleZ
13:36:21 05/20/12
Agreed this sounds like a belt...
beanz
09:31:22 05/20/12
if that explains it, there is a ton of slippage because it
not4resaleZ
13:35:10 05/20/12
Until the fan starts to spin?
njz
06:13:01 05/20/12
It always spins when running. (n/m)
not4resaleZ
13:37:10 05/20/12
